show ipstats
show ipstats {ipv4} [{vlan name } | {tunnel} tunnel_name]
Description
Displays IP statistics for the switch CPU for a particular VLAN.
Syntax Description
name Specifies a VLAN name.
tunnel_name Specifies a tunnel name.
Default
N/A.
Usage Guidelines
This command only shows statistics of the CPU-handled packets. Not all packets are handled by the CPU.
The fields displayed in the show ipstats command are defined in the following tables.
Table 1. Router Interface Statistics Field Definitions
Field Definition
Packets IN/OUT Total number of IP packets received or transmitted on a VLAN router interface.
Octets IN/OUT Total number of octets received or transmitted on a VLAN router interface.
Mcast packets IN/OUT Total number of multicast packets received or transmitted on a VLAN router interface.
Bcast packets IN/OUT Total number of broadcast packets received or transmitted on a VLAN router interface.
Errors IN/OUT Total number of IP packets with errors received or transmitted on a VLAN router interface.
Discards IN/OUT Total number of IP packets that cannot travel up to the CPU due to lack of buffer space.
Unknown Protocols IN/OUT Total number of IP packets with unknown upper layer protocols received by the router interface.
The following example displays IP statistics for the VLAN "accounting":
show ipstats vlan accounting
The ipv4 keyword was added in ExtremeXOS 11.2.
The VR option was removed in ExtremeXOS 30.1.
Platform Availability
